editYou may have configured Logstash or Packetbeat incorrectly. To resolve the issue:
Make sure that Logstash is running and you can connect to it. First, try to ping the Logstash host to verify that you can reach it from the host running Packetbeat. Then use either
nc
ortelnet
- Verify that the config file for Packetbeat specifies the correct port where Logstash is running.
