URI parts processor
Parses a Uniform Resource Identifier (URI) string and extracts its components as an object. This URI object includes properties for the URI’s domain, path, fragment, port, query, scheme, user info, username, and password.
Table 47. URI Parts Options
Name Required Default Description
field
yes
Field containing the URI string.
target_field
no
url
Output field for the URI object.
keep_original
no
true
If true, the processor copies the unparsed URI to <target_field>.original.
remove_if_successful
no
false
If true, the processor removes the field after parsing the URI string. If parsing fails, the processor does not remove the field.
ignore_missing
no
false
If true and field does not exist, the processor quietly exits without modifying the document
description
no
Description of the processor. Useful for describing the purpose of the processor or its configuration.
if
no
Conditionally execute the processor. See Conditionally run a processor.
ignore_failure
no
false
Ignore failures for the processor. See Handling pipeline failures.
on_failure
no
Handle failures for the processor. See Handling pipeline failures.
tag
no
Identifier for the processor. Useful for debugging and metrics.
  "description" : "...",
  "processors" : [
      "uri_parts": {
        "field": "input_field",
        "target_field": "url",
        "keep_original": true,
        "remove_if_successful": false
  "_source": {
    "input_field": "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment"
It produces this result:
"_source" : {
  "input_field" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
  "url" : {
    "path" : "/foo.gif",
    "fragment" : "fragment",
    "extension" : "gif",
    "password" : "mypassword",
    "original" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
    "scheme" : "http",
    "port" : 80,
    "user_info" : "myusername:mypassword",
    "domain" : "www.example.com",
    "query" : "key1=val1&key2=val2",
    "username" : "myusername"
