- Metricbeat overview
- Set up and run
- Upgrade Metricbeat
- How Metricbeat works
- Configure
- Modules
- General settings
- Project paths
- Config file loading
- Output
- Kerberos
- SSL
- Kibana endpoint
- Kibana dashboards
- Processors
- Define processors
- add_cloud_metadata
- add_cloudfoundry_metadata
- add_docker_metadata
- add_fields
- add_host_metadata
- add_id
- add_kubernetes_metadata
- add_labels
- add_locale
- add_network_direction
- add_observer_metadata
- add_process_metadata
- add_tags
- community_id
- convert
- copy_fields
- decode_base64_field
- decode_json_fields
- decompress_gzip_field
- detect_mime_type
- dissect
- dns
- drop_event
- drop_fields
- extract_array
- fingerprint
- include_fields
- rate_limit
- registered_domain
- rename
- script
- translate_sid
- truncate_fields
- urldecode
- decode_xml
- Autodiscover
- Internal queue
- Logging
- HTTP endpoint
- Regular expression support
- Instrumentation
- metricbeat.reference.yml
- How to guides
- Beats central management
- Modules
- ActiveMQ module
- Aerospike module
- Apache module
- App Search module
- AWS module
- AWS billing metricset
- AWS cloudwatch metricset
- AWS dynamodb metricset
- AWS ebs metricset
- AWS ec2 metricset
- AWS elb metricset
- AWS lambda metricset
- AWS natgateway metricset
- AWS rds metricset
- AWS s3_request metricset
- AWS sns metricset
- AWS sqs metricset
- AWS usage metricset
- AWS vpn metricset
- AWS Fargate module
- Azure module
- Azure app_state metricset
- Azure billing metricset
- Azure compute_vm metricset
- Azure monitor metricset
- Azure storage metricset
- Beat module
- Ceph module
- Ceph cluster_disk metricset
- Ceph mgr_osd_perf metricset
- Ceph mgr_osd_tree metricset
- Ceph osd_df metricset
- Ceph osd_tree metricset
- Ceph pool_disk metricset
- Cloudfoundry module
- CockroachDB module
- Consul module
- Coredns module
- Couchbase module
- CouchDB module
- Docker module
- Dropwizard module
- Elasticsearch module
- Elasticsearch ccr metricset
- Envoyproxy module
- Etcd module
- Golang module
- Graphite module
- HAProxy module
- HTTP module
- IBM MQ module
- IIS module
- Istio module
- Jolokia module
- Kafka module
- Kibana module
- Kubernetes module
- Kubernetes event metricset
- Kubernetes node metricset
- Kubernetes pod metricset
- Kubernetes proxy metricset
- Kubernetes system metricset
- Kubernetes volume metricset
- KVM module
- linux module
- Logstash module
- Memcached module
- MongoDB module
- MSSQL module
- Munin module
- MySQL module
- NATS module
- Nginx module
- Openmetrics module
- Oracle module
- PHP_FPM module
- PostgreSQL module
- Prometheus module
- RabbitMQ module
- Redis module
- Redis Enterprise module
- SQL module
- Stan module
- Statsd module
- System module
- System core metricset
- System cpu metricset
- System diskio metricset
- System entropy metricset
- System filesystem metricset
- System fsstat metricset
- System load metricset
- System memory metricset
- System network metricset
- System process metricset
- System raid metricset
- System service metricset
- System socket metricset
- System uptime metricset
- System users metricset
- Tomcat module
- Traefik module
- uWSGI module
- vSphere module
- Windows module
- ZooKeeper module
- Exported fields
- ActiveMQ fields
- Aerospike fields
- Apache fields
- App Search fields
- AWS fields
- AWS Fargate fields
- Azure fields
- Beat fields
- Beat fields
- Ceph fields
- Cloudfoundry fields
- CockroachDB fields
- Common fields
- Consul fields
- Coredns fields
- Couchbase fields
- CouchDB fields
- Docker fields
- Docker fields
- Dropwizard fields
- ECS fields
- Elasticsearch fields
- Envoyproxy fields
- Etcd fields
- Golang fields
- Graphite fields
- HAProxy fields
- Host fields
- HTTP fields
- IBM MQ fields
- IIS fields
- Istio fields
- Jolokia fields
- Kafka fields
- Kibana fields
- Kubernetes fields
- Kubernetes fields
- KVM fields
- linux fields
- Logstash fields
- Memcached fields
- MongoDB fields
- MSSQL fields
- Munin fields
- MySQL fields
- NATS fields
- Nginx fields
- Openmetrics fields
- Oracle fields
- PHP_FPM fields
- PostgreSQL fields
- Process fields
- Prometheus fields
- RabbitMQ fields
- Redis fields
- Redis Enterprise fields
- SQL fields
- Stan fields
- Statsd fields
- System fields
- Tomcat fields
- Traefik fields
- uWSGI fields
- vSphere fields
- Windows fields
- ZooKeeper fields
- Monitor
- Secure
- Troubleshoot
- Get help
- Debug
- Common problems
- Error loading config file
- Contribute to Beats
editYou may have configured Logstash or Metricbeat incorrectly. To resolve the issue:
Make sure that Logstash is running and you can connect to it. First, try to ping the Logstash host to verify that you can reach it from the host running Metricbeat. Then use either
nc
ortelnet
- Verify that the config file for Metricbeat specifies the correct port where Logstash is running.
Was this helpful?
Thank you for your feedback.
