- Overview
- Getting started with Metricbeat
- Setting up and running Metricbeat
- Upgrading Metricbeat
- How Metricbeat works
- Configuring Metricbeat
- Specify which modules to run
- Specify general settings
- Load external configuration files
- Configure the internal queue
- Configure the output
- Configure index lifecycle management
- Specify SSL settings
- Filter and enhance the exported data
- Define processors
- Add cloud metadata
- Add Docker metadata
- Add fields
- Add Host metadata
- Add Kubernetes metadata
- Add labels
- Add the local time zone
- Add Observer metadata
- Add process metadata
- Add tags
- Community ID Network Flow Hash
- Convert
- Decode Base64 fields
- Decode JSON fields
- Decompress gzip fields
- Dissect strings
- DNS Reverse Lookup
- Drop events
- Drop fields from events
- Extract array
- Keep fields from events
- Registered Domain
- Rename fields from events
- Parse data by using ingest node
- Configure project paths
- Configure the Kibana endpoint
- Load the Kibana dashboards
- Configure logging
- Autodiscover
- YAML tips and gotchas
- Regular expression support
- HTTP Endpoint
- metricbeat.reference.yml
- Beats central management
- Modules
- Aerospike module
- Apache module
- App Search module
- aws module
- azure module
- Beat module
- Ceph module
- CockroachDB module
- consul module
- coredns module
- Couchbase module
- couchdb module
- Docker module
- Dropwizard module
- Elasticsearch module
- Elasticsearch ccr metricset
- envoyproxy module
- Etcd module
- Golang module
- Graphite module
- HAProxy module
- HTTP module
- Jolokia module
- Kafka module
- Kibana module
- Kubernetes module
- Kubernetes event metricset
- Kubernetes node metricset
- Kubernetes pod metricset
- Kubernetes proxy metricset
- Kubernetes system metricset
- Kubernetes volume metricset
- kvm module
- Logstash module
- Memcached module
- MongoDB module
- MSSQL module
- Munin module
- MySQL module
- Nats module
- Nginx module
- Oracle module
- PHP_FPM module
- PostgreSQL module
- Prometheus module
- RabbitMQ module
- Redis module
- Statsd module
- System module
- System core metricset
- System cpu metricset
- System diskio metricset
- System entropy metricset
- System filesystem metricset
- System fsstat metricset
- System load metricset
- System memory metricset
- System network metricset
- System process metricset
- System raid metricset
- System socket metricset
- System uptime metricset
- Tomcat module
- traefik module
- uwsgi module
- vSphere module
- Windows module
- ZooKeeper module
- Exported fields
- Aerospike fields
- Apache fields
- App Search fields
- aws fields
- azure fields
- Beat fields
- Beat fields
- Ceph fields
- CockroachDB fields
- Common fields
- consul fields
- coredns fields
- Couchbase fields
- couchdb fields
- Docker fields
- Docker fields
- Dropwizard fields
- ECS fields
- Elasticsearch fields
- envoyproxy fields
- Etcd fields
- Golang fields
- Graphite fields
- HAProxy fields
- Host fields
- HTTP fields
- Jolokia fields
- Kafka fields
- Kibana fields
- Kubernetes fields
- Kubernetes fields
- kvm fields
- Logstash fields
- Memcached fields
- MongoDB fields
- MSSQL fields
- Munin fields
- MySQL fields
- Nats fields
- Nginx fields
- Oracle fields
- PHP_FPM fields
- PostgreSQL fields
- Process fields
- Prometheus fields
- RabbitMQ fields
- Redis fields
- Statsd fields
- System fields
- Tomcat fields
- traefik fields
- uwsgi fields
- vSphere fields
- Windows fields
- ZooKeeper fields
- Monitoring Metricbeat
- Securing Metricbeat
- Get help
- Debug
- Common problems
- Error loading config file
- Contributing to Beats
editYou may have configured Logstash or Metricbeat incorrectly. To resolve the issue:
Make sure that Logstash is running and you can connect to it. First, try to ping the Logstash host to verify that you can reach it from the host running Metricbeat. Then use either
nc
ortelnet
- Verify that the config file for Metricbeat specifies the correct port where Logstash is running.
Was this helpful?
Thank you for your feedback.
