- Packetbeat Reference: other versions:
- Overview
- Getting started with Packetbeat
- Setting up and running Packetbeat
- Upgrading Packetbeat
- Configuring Packetbeat
- Set traffic capturing options
- Set up flows to monitor network traffic
- Specify which transaction protocols to monitor
- Specify which processes to monitor
- Specify general settings
- Configure the internal queue
- Configure the output
- Configure index lifecycle management
- Specify SSL settings
- Filter and enhance the exported data
- Define processors
- Add cloud metadata
- Add fields
- Add labels
- Add the local time zone
- Add tags
- Decode JSON fields
- Decode Base64 fields
- Decompress gzip fields
- Community ID Network Flow Hash
- Convert
- Drop events
- Drop fields from events
- Extract array
- Keep fields from events
- Registered Domain
- Rename fields from events
- Add Kubernetes metadata
- Add Docker metadata
- Add Host metadata
- Add Observer metadata
- Dissect strings
- DNS Reverse Lookup
- Add process metadata
- Parse data by using ingest node
- Configure project paths
- Configure the Kibana endpoint
- Load the Kibana dashboards
- Configure logging
- YAML tips and gotchas
- HTTP Endpoint
- packetbeat.reference.yml
- Exported fields
- AMQP fields
- Beat fields
- Cassandra fields
- Common fields
- DHCPv4 fields
- DNS fields
- Docker fields
- ECS fields
- Flow Event fields
- Host fields
- HTTP fields
- ICMP fields
- Kubernetes fields
- Memcache fields
- MongoDb fields
- MySQL fields
- NFS fields
- PostgreSQL fields
- Process fields
- Raw fields
- Redis fields
- Thrift-RPC fields
- TLS fields
- Transaction Event fields
- Measurements (Transactions) fields
- Monitoring Packetbeat
- Securing Packetbeat
- Visualizing Packetbeat data in Kibana
- Get help
- Debug
- Record a trace
- Common problems
- Packetbeat doesn’t see any packets when using mirror ports
- Packetbeat can’t capture traffic from Windows loopback interface
- Packetbeat is missing long running transactions
- Packetbeat isn’t capturing MySQL performance data
- Packetbeat uses too much bandwidth
- Error loading config file
- Fields show up as nested JSON in Kibana
- Contributing to Beats
editYou may have configured Logstash or Packetbeat incorrectly. To resolve the issue:
Make sure that Logstash is running and you can connect to it. First, try to ping the Logstash host to verify that you can reach it from the host running Packetbeat. Then use either
nc
ortelnet
- Verify that the config file for Packetbeat specifies the correct port where Logstash is running.
Was this helpful?
Thank you for your feedback.
