New
Read more
URI parts processor
Parses a Uniform Resource Identifier (URI) string and extracts its components as an object. This URI object includes properties for the URI’s domain, path, fragment, port, query, scheme, user info, username, and password.
Table 40. URI Parts Options
Name Required Default Description
field
yes
Field containing the URI string.
target_field
no
url
Output field for the URI object.
keep_original
no
true
If true, the processor copies the unparsed URI to <target_field>.original.
remove_if_successful
no
false
If true, the processor removes the field after parsing the URI string. If parsing fails, the processor does not remove the field.
if
no
Conditionally execute this processor.
on_failure
no
Handle failures for this processor. See Handling failures in pipelines.
ignore_failure
no
false
Ignore failures for this processor. See Handling failures in pipelines.
tag
no
An identifier for this processor. Useful for debugging and metrics.
  "description" : "...",
  "processors" : [
      "uri_parts": {
        "field": "input_field",
        "target_field": "url",
        "keep_original": true,
        "remove_if_successful": false
  "_source": {
    "input_field": "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment"
It produces this result:
"_source" : {
  "input_field" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
  "url" : {
    "path" : "/foo.gif",
    "fragment" : "fragment",
    "extension" : "gif",
    "password" : "mypassword",
    "original" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
    "scheme" : "http",
    "port" : 80,
    "user_info" : "myusername:mypassword",
    "domain" : "www.example.com",
    "query" : "key1=val1&key2=val2",
    "username" : "myusername"
Was this helpful?
Feedback
