- What’s new in 8.17
- Elasticsearch basics
- Quick starts
- Set up Elasticsearch
- Run Elasticsearch locally
- Installing Elasticsearch
- Configuring Elasticsearch
- Auditing settings
- Circuit breaker settings
- Field data cache settings
- Local gateway settings
- Health Diagnostic settings
- Index management settings
- Index recovery settings
- Indexing buffer settings
- Inference settings
- License settings
- Machine learning settings
- Node settings
- Networking
- Node query cache settings
- Path settings
- Search settings
- Transforms settings
- Thread pools
- Watcher settings
- Set JVM options
- Bootstrap Checks
- Heap size check
- File descriptor check
- Memory lock check
- Max file size check
- Maximum map count check
- Client JVM check
- Use serial collector check
- System call filter check
- Early-access check
- All permission check
- Bootstrap Checks for X-Pack
- Starting Elasticsearch
- Stopping Elasticsearch
- Remote clusters
- Plugins
- Upgrade Elasticsearch
- Index modules
- Mapping
- Dynamic mapping
- Explicit mapping
- Runtime fields
- Field data types
- Aggregate metric
- Alias
- Arrays
- Binary
- Boolean
- Completion
- Date
- Date nanoseconds
- Dense vector
- Flattened
- Geopoint
- Geoshape
- Histogram
- IP
- Join
- Keyword
- Nested
- Numeric
- Object
- Pass-through object
- Percolator
- Point
- Range
- Rank feature
- Rank features
- Search-as-you-type
- Semantic text
- Shape
- Sparse vector
- Text
- Token count
- Unsigned long
- Version
- Metadata fields
- Mapping parameters
analyzer
coerce
copy_to
doc_values
dynamic
eager_global_ordinals
enabled
format
ignore_above
index.mapping.ignore_above
ignore_malformed
index
index_options
index_phrases
index_prefixes
meta
fields
normalizer
norms
null_value
position_increment_gap
properties
search_analyzer
similarity
store
subobjects
term_vector
- Mapping limit settings
- Removal of mapping types
- Text analysis
- Overview
- Concepts
- Configure text analysis
- Built-in analyzer reference
- Tokenizer reference
- Token filter reference
- Apostrophe
- ASCII folding
- CJK bigram
- CJK width
- Classic
- Common grams
- Conditional
- Decimal digit
- Delimited payload
- Dictionary decompounder
- Edge n-gram
- Elision
- Fingerprint
- Flatten graph
- Hunspell
- Hyphenation decompounder
- Keep types
- Keep words
- Keyword marker
- Keyword repeat
- KStem
- Length
- Limit token count
- Lowercase
- MinHash
- Multiplexer
- N-gram
- Normalization
- Pattern capture
- Pattern replace
- Phonetic
- Porter stem
- Predicate script
- Remove duplicates
- Reverse
- Shingle
- Snowball
- Stemmer
- Stemmer override
- Stop
- Synonym
- Synonym graph
- Trim
- Truncate
- Unique
- Uppercase
- Word delimiter
- Word delimiter graph
- Character filters reference
- Normalizers
- Index templates
- Data streams
- Ingest pipelines
- Example: Parse logs
- Enrich your data
- Processor reference
- Append
- Attachment
- Bytes
- Circle
- Community ID
- Convert
- CSV
- Date
- Date index name
- Dissect
- Dot expander
- Drop
- Enrich
- Fail
- Fingerprint
- Foreach
- Geo-grid
- GeoIP
- Grok
- Gsub
- HTML strip
- Inference
- IP Location
- Join
- JSON
- KV
- Lowercase
- Network direction
- Pipeline
- Redact
- Registered domain
- Remove
- Rename
- Reroute
- Script
- Set
- Set security user
- Sort
- Split
- Terminate
- Trim
- Uppercase
- URL decode
- URI parts
- User agent
- Ingest pipelines in Search
- Aliases
- Search your data
- The search API
- Sort search results
- Paginate search results
- Retrieve selected fields
- Search multiple data streams and indices using a query
- Collapse search results
- Filter search results
- Highlighting
- Long-running searches
- Near real-time search
- Retrieve inner hits
- Search shard routing
- Searching with query rules
- Search templates
- Full-text search
- Search relevance optimizations
- Retrievers
- kNN search
- Semantic search
- Retrieval augmented generation
- Search across clusters
- Search with synonyms
- Search Applications
- Search analytics
- The search API
- Re-ranking
- Query DSL
- Aggregations
- Bucket aggregations
- Adjacency matrix
- Categorize text
- Children
- Composite
- Date histogram
- Date range
- Diversified sampler
- Filter
- Filters
- Frequent item sets
- Geo-distance
- Geohash grid
- Geohex grid
- Geotile grid
- Global
- Histogram
- IP prefix
- IP range
- Missing
- Multi Terms
- Nested
- Parent
- Random sampler
- Range
- Rare terms
- Reverse nested
- Sampler
- Significant terms
- Significant text
- Terms
- Time series
- Variable width histogram
- Metrics aggregations
- Pipeline aggregations
- Average bucket
- Bucket script
- Bucket count K-S test
- Bucket correlation
- Bucket selector
- Bucket sort
- Change point
- Cumulative cardinality
- Cumulative sum
- Derivative
- Extended stats bucket
- Inference bucket
- Max bucket
- Min bucket
- Moving function
- Moving percentiles
- Normalize
- Percentiles bucket
- Serial differencing
- Stats bucket
- Sum bucket
- Geospatial analysis
- Connectors
- EQL
- ES|QL
- SQL
- Overview
- Getting Started with SQL
- Conventions and Terminology
- SQL REST API
- SQL Translate API
- SQL CLI
- SQL JDBC
- SQL ODBC
- SQL Client Applications
- SQL Language
- Functions and Operators
- Comparison Operators
- Logical Operators
- Math Operators
- Cast Operators
- LIKE and RLIKE Operators
- Aggregate Functions
- Grouping Functions
- Full-Text Search Functions
- Mathematical Functions
- String Functions
- Type Conversion Functions
- Geo Functions
- System Functions
- Reserved keywords
- SQL Limitations
- Scripting
- Data management
- Tutorial: Automate rollover
- Index management in Kibana
- Overview
- Concepts
- Index lifecycle actions
- Manage existing indices
- Skip rollover
- Data tiers
- Autoscaling
- Monitor a cluster
- Snapshot and restore
- Secure the Elastic Stack
- Manually configure security
- User authentication
- Built-in users
- Service accounts
- Internal users
- User profiles
- Realms
- Realm chains
- Security domains
- LDAP user authentication
- Native user authentication
- PKI user authentication
- SAML authentication
- Kerberos authentication
- JWT authentication
- Enabling anonymous access
- Controlling the user cache
- User authorization
- Built-in roles
- Defining roles
- Role restriction
- Security privileges
- Document level security
- Field level security
- Enable audit logging
- Operator privileges
- Authorization exceptions
- Common SSL/TLS exceptions
- Common Kerberos exceptions
- Common SAML issues
- Limitations
- Watcher
- Cross-cluster replication
- Data store architecture
- REST APIs
- API conventions
- Common options
- REST API compatibility
- Autoscaling APIs
- Behavioral Analytics APIs
- cat aliases
- cat allocation
- cat anomaly detectors
- cat component templates
- cat count
- cat data frame analytics
- cat datafeeds
- cat fielddata
- cat health
- cat indices
- cat master
- cat nodeattrs
- cat nodes
- cat pending tasks
- cat plugins
- cat recovery
- cat repositories
- cat segments
- cat shards
- cat snapshots
- cat task management
- cat templates
- cat thread pool
- cat trained model
- cat transforms
- Cluster APIs
- Cluster allocation explain
- Cluster get settings
- Cluster health
- Health
- Cluster reroute
- Cluster state
- Cluster stats
- Cluster update settings
- Nodes feature usage
- Nodes hot threads
- Nodes info
- Prevalidate node removal
- Nodes stats
- Cluster Info
- Pending cluster tasks
- Remote cluster info
- Task management
- Get desired nodes
- Delete desired nodes
- Get desired balance
- Reset desired balance
- Connector APIs
- Create connector
- Delete connector
- Get connector
- List connectors
- Update connector API key id
- Update connector index name
- Update connector features
- Update connector filtering
- Update connector pipeline
- Update connector scheduling
- Create connector sync job
- Cancel connector sync job
- Delete connector sync job
- Get connector sync job
- List connector sync jobs
- Check in a connector
- Update connector error
- Update connector status
- Check in connector sync job
- Claim connector sync job
- Data stream APIs
- Document APIs
- Enrich APIs
- EQL APIs
- ES|QL APIs
- Features APIs
- Fleet APIs
- Graph explore API
- Index APIs
- Alias exists
- Aliases
- Analyze
- Analyze index disk usage
- Clear cache
- Clone index
- Close index
- Create index
- Create or update alias
- Delete component template
- Delete dangling index
- Delete alias
- Delete index
- Delete index template
- Exists
- Field usage stats
- Flush
- Force merge
- Get alias
- Get component template
- Get field mapping
- Get index
- Get index settings
- Get index template
- Get index template (legacy)
- Get mapping
- Import dangling index
- Index recovery
- Index segments
- Index shard stores
- Index stats
- List dangling indices
- Open index
- Refresh
- Resolve index
- Resolve cluster
- Advantages of using this endpoint before a cross-cluster search
- Rollover
- Shrink index
- Simulate index
- Simulate template
- Split index
- Unfreeze index
- Update index settings
- Update mapping
- Get policy
- Delete policy
- Move to step
- Remove policy
- Retry policy
- Explain lifecycle
- Inference APIs
- Delete inference API
- Get inference API
- Perform inference API
- Create inference API
- Stream inference API
- Update inference API
- ELSER inference integration
- Info API
- Ingest APIs
- Licensing APIs
- Logstash APIs
- Add events to calendar
- Add jobs to calendar
- Close jobs
- Create jobs
- Create calendars
- Create datafeeds
- Create filters
- Delete calendars
- Delete datafeeds
- Delete events from calendar
- Delete filters
- Delete forecasts
- Delete jobs
- Delete jobs from calendar
- Delete model snapshots
- Delete expired data
- Estimate model memory
- Flush jobs
- Forecast jobs
- Get buckets
- Get calendars
- Get categories
- Get datafeeds
- Get datafeed statistics
- Get influencers
- Get jobs
- Get job statistics
- Get model snapshots
- Get overall buckets
- Get scheduled events
- Get filters
- Get records
- Open jobs
- Post data to jobs
- Preview datafeeds
- Reset jobs
- Revert model snapshots
- Start datafeeds
- Stop datafeeds
- Update datafeeds
- Update filters
- Update jobs
- Update model snapshots
- Upgrade model snapshots
- Create trained models
- Delete trained models
- Get trained models
- Get trained models stats
- Infer trained model
- Migration APIs
- Node lifecycle APIs
- Query rules APIs
- Reload search analyzers API
- Repositories metering APIs
- Rollup APIs
- Root API
- Script APIs
- Search APIs
- Search Application APIs
- Searchable snapshots APIs
- Security APIs
- Authenticate
- Change passwords
- Clear cache
- Clear roles cache
- Clear privileges cache
- Clear API key cache
- Create API keys
- Create or update roles
- Bulk delete roles API
- Create or update users
- Delegate PKI authentication
- Delete role mappings
- Delete roles
- Delete users
- Disable users
- Enable users
- Enroll Kibana
- Enroll node
- Get API key information
- Get application privileges
- Get builtin privileges
- Get role mappings
- Get roles
- Query Role
- Get service accounts
- Get Security settings
- Get token
- Get user privileges
- Get users
- Grant API keys
- Has privileges
- Invalidate API key
- Invalidate token
- OpenID Connect authenticate
- OpenID Connect logout
- Query API key information
- Query User
- Update API key
- Update Security settings
- Bulk update API keys
- SAML prepare authentication
- SAML authenticate
- SAML logout
- SAML invalidate
- SAML complete logout
- SSL certificate
- Activate user profile
- Disable user profile
- Enable user profile
- Get user profiles
- Suggest user profile
- Update user profile data
- Has privileges user profile
- Snapshot and restore APIs
- SQL APIs
- Synonyms APIs
- Text structure APIs
- Transform APIs
- Usage API
- Watcher APIs
- Definitions
- elasticsearch-certgen
- elasticsearch-certutil
- elasticsearch-croneval
- elasticsearch-keystore
- elasticsearch-node
- elasticsearch-saml-metadata
- elasticsearch-shard
- elasticsearch-syskeygen
- elasticsearch-users
- Optimizations
- Fix common cluster issues
- Diagnose unassigned shards
- Troubleshooting corruption
- Fix data nodes out of disk
- Restore from snapshot
- Troubleshooting discovery
- Troubleshooting monitoring
- Troubleshooting transforms
- Troubleshooting Watcher
- Troubleshooting searches
- Capture diagnostics
- Migration guide
- Elasticsearch version 8.17.3
- Elasticsearch version 8.17.2
- Elasticsearch version 8.17.1
- Elasticsearch version 8.17.0
- Elasticsearch version 8.9.2
- Elasticsearch version 8.9.1
- Elasticsearch version 8.9.0
- Elasticsearch version 8.8.2
- Elasticsearch version 8.8.1
- Elasticsearch version 8.8.0
- Elasticsearch version 8.7.1
- Elasticsearch version 8.7.0
- Elasticsearch version 8.6.2
- Elasticsearch version 8.6.1
- Elasticsearch version 8.6.0
- Elasticsearch version 8.5.3
- Elasticsearch version 8.5.2
- Elasticsearch version 8.5.1
- Elasticsearch version 8.5.0
- Elasticsearch version 8.4.3
- Elasticsearch version 8.4.2
- Elasticsearch version 8.4.1
- Elasticsearch version 8.4.0
- Elasticsearch version 8.3.3
- Elasticsearch version 8.3.2
- Elasticsearch version 8.3.1
- Elasticsearch version 8.3.0
- Elasticsearch version 8.2.3
- Elasticsearch version 8.2.2
- Elasticsearch version 8.2.1
- Elasticsearch version 8.2.0
- Elasticsearch version 8.1.3
- Elasticsearch version 8.1.2
- Elasticsearch version 8.1.1
- Elasticsearch version 8.1.0
- Elasticsearch version 8.0.1
- Elasticsearch version 8.0.0
- Dependencies and versions
editIndex management settings
editYou can use the following cluster settings to enable or disable index management features.
action.auto_create_index
(Dynamic)
Automatically create an index if it doesn’t already exist and apply any configured index templates. Defaults to
true
action.destructive_requires_name
(Dynamic)
When set to
true
, you must specify the index name to delete an index. It is not possible to delete all indices with_all
or use wildcards. Defaults totrue
cluster.indices.close.enable
(Dynamic) Enables closing of open indices in Elasticsearch. If
false
, you cannot close open indices. Defaults totrue
.Closed indices still consume a significant amount of disk space.
stack.templates.enabled
(Dynamic) If
true
, enables built-in index and component templates. Elastic Agent uses these templates to create data streams. Iffalse
, Elasticsearch disables these index and component templates. Defaults totrue
.It is not recommended to disable the built-in stack templates, as some functionality of Elasticsearch or Kibana will not work correctly when disabled. Features like log and metric collection, as well as Kibana reporting, may malfunction without the built-in stack templates. Stack templates should only be disabled temporarily, if necessary, to resolve upgrade issues, then re-enabled after any issues have been resolved.
This setting affects the following built-in index templates:
logs-*-*
metrics-*-*
synthetics-*-*
profiling-*
security_solution-*-*
This setting also affects the following built-in component templates:
logs@mappings
logs@settings
metrics@mappings
metrics@settings
metrics@tsdb-settings
synthetics@mapping
synthetics@settings
Reindex settings
edit-
reindex.remote.whitelist
(Static)
Specifies the hosts that can be reindexed from remotely. Expects a YAML array of
host:port
strings. Consists of a comma-delimited list ofhost:port
entries. Defaults to["\*.io:*", "\*.com:*"]
reindex.ssl.certificate
Specifies the path to the PEM encoded certificate (or certificate chain) to be
used for HTTP client authentication (if required by the remote cluster)
This setting requires that
reindex.ssl.key
also be set. You cannot specify bothreindex.ssl.certificate
andreindex.ssl.keystore.path
reindex.ssl.certificate_authorities
List of paths to PEM encoded certificate files that should be trusted.
andreindex.ssl.truststore.path
reindex.ssl.key
Specifies the path to the PEM encoded private key associated with the
certificate used for client authentication (
). You cannot specify bothreindex.ssl.key
reindex.ssl.key_passphrase
Specifies the passphrase to decrypt the PEM encoded private key
reindex.ssl.key
) if it is encrypted. [7.17.0] Deprecated in 7.17.0. Preferreindex.ssl.secure_key_passphrase
instead. Cannot be used withreindex.ssl.secure_key_passphrase
reindex.ssl.keystore.key_password
The password for the key in the keystore (
). Defaults to the keystore password. [7.17.0] Deprecated in 7.17.0. Preferreindex.ssl.keystore.secure_key_password
instead. This setting cannot be used withreindex.ssl.keystore.secure_key_password
reindex.ssl.keystore.password
The password to the keystore (
). [7.17.0] Deprecated in 7.17.0. Preferreindex.ssl.keystore.secure_password
instead. This setting cannot be used withreindex.ssl.keystore.secure_password
Specifies the path to the keystore that contains a private key and certificate
to be used for HTTP client authentication (if required by the remote cluster).
This keystore can be in "JKS" or "PKCS#12" format.
reindex.ssl.key
reindex.ssl.keystore.type
The type of the keystore (
). Must be eitherjks
orPKCS12
. If the keystore path ends in ".p12", ".pfx" or "pkcs12", this setting defaults toPKCS12
. Otherwise, it defaults tojks
(Secure) -
reindex.ssl.key
) if it is encrypted. Cannot be used withreindex.ssl.key_passphrase
(Secure) -
). Defaults to the keystore password. This setting cannot be used withreindex.ssl.keystore.key_password
(Secure) -
). This setting cannot be used withreindex.ssl.keystore.password
reindex.ssl.truststore.password
The password to the truststore (
). [7.17.0] Deprecated in 7.17.0. Preferreindex.ssl.truststore.secure_password
instead. This setting cannot be used withreindex.ssl.truststore.secure_password
The path to the Java Keystore file that contains the certificates to trust.
(Secure) -
). This setting cannot be used withreindex.ssl.truststore.password
reindex.ssl.truststore.type
The type of the truststore (
orPKCS12
. If the truststore path ends in ".p12", ".pfx" or "pkcs12", this setting defaults toPKCS12
reindex.ssl.verification_mode
Indicates the type of verification to protect against man in the middle attacks
and certificate forgery.
One of
full
(verify the hostname and the certificate path),certificate
(verify the certificate path, but not the hostname) ornone
(perform no verification - this is strongly discouraged in production environments). Defaults tofull
