- Filebeat overview
- Set up and run
- Upgrade
- How Filebeat works
- Configure
- Inputs
- Multiline messages
- AWS CloudWatch
- AWS S3
- Azure Event Hub
- Azure Blob Storage
- Benchmark
- CEL
- Cloud Foundry
- CometD
- Container
- Entity Analytics
- ETW
- filestream
- GCP Pub/Sub
- Google Cloud Storage
- HTTP Endpoint
- HTTP JSON
- journald
- Kafka
- Log
- MQTT
- NetFlow
- Office 365 Management Activity API
- Redis
- Salesforce
- Stdin
- Streaming
- Syslog
- TCP
- UDP
- Unix
- winlog
- Modules
- General settings
- Project paths
- Config file loading
- Output
- Kerberos
- SSL
- Kibana endpoint
- Kibana dashboards
- Processors
- Define processors
- add_cloud_metadata
- add_cloudfoundry_metadata
- add_docker_metadata
- add_fields
- add_host_metadata
- add_id
- add_kubernetes_metadata
- add_labels
- add_locale
- add_network_direction
- add_nomad_metadata
- add_observer_metadata
- add_process_metadata
- add_tags
- append
- cache
- community_id
- convert
- copy_fields
- decode_base64_field
- decode_cef
- decode_csv_fields
- decode_duration
- decode_json_fields
- decode_xml
- decode_xml_wineventlog
- decompress_gzip_field
- detect_mime_type
- dissect
- dns
- drop_event
- drop_fields
- extract_array
- fingerprint
- include_fields
- move_fields
- parse_aws_vpc_flow_log
- rate_limit
- registered_domain
- rename
- replace
- script
- syslog
- timestamp
- translate_ldap_attribute
- translate_sid
- truncate_fields
- urldecode
- Autodiscover
- Internal queue
- Logging
- HTTP endpoint
- Regular expression support
- Instrumentation
- Feature flags
- filebeat.reference.yml
- Inputs
- How to guides
- Change the index name
- Load Kibana dashboards
- Load ingest pipelines
- Deduplicate data
- Parse data using an ingest pipeline
- Migrate
log
input configurations tofilestream
- Migrating from a Deprecated Filebeat Module
- Modules
- Modules overview
- ActiveMQ module
- Apache module
- Auditd module
- AWS module
- AWS Fargate module
- Azure module
- CEF module
- Check Point module
- Cisco module
- CoreDNS module
- CrowdStrike module
- Cyberark PAS module
- Elasticsearch module
- Envoyproxy Module
- Fortinet module
- Google Cloud module
- Google Workspace module
- HAproxy module
- IBM MQ module
- Icinga module
- IIS module
- Iptables module
- Juniper module
- Kafka module
- Kibana module
- Logstash module
- Microsoft module
- MISP module
- MongoDB module
- MSSQL module
- MySQL module
- MySQL Enterprise module
- NATS module
- NetFlow module
- Nginx module
- Office 365 module
- Okta module
- Oracle module
- Osquery module
- Palo Alto Networks module
- pensando module
- PostgreSQL module
- RabbitMQ module
- Redis module
- Salesforce module
- Santa module
- Snyk module
- Sophos module
- Suricata module
- System module
- Threat Intel module
- Traefik module
- Zeek (Bro) Module
- ZooKeeper module
- Zoom module
- Exported fields
- ActiveMQ fields
- Apache fields
- Auditd fields
- AWS fields
- AWS CloudWatch fields
- AWS Fargate fields
- Azure fields
- Beat fields
- CEF fields
- Checkpoint fields
- Cisco fields
- Coredns fields
- Crowdstrike fields
- CyberArk PAS fields
- Docker fields
- ECS fields
- Elasticsearch fields
- Envoyproxy fields
- Fortinet fields
- google_workspace fields
- HAProxy fields
- Host fields
- ibmmq fields
- Icinga fields
- IIS fields
- iptables fields
- Juniper JUNOS fields
- Kafka fields
- kibana fields
- Kubernetes fields
- Log file content fields
- logstash fields
- Lumberjack fields
- Microsoft fields
- MISP fields
- mongodb fields
- mssql fields
- MySQL fields
- MySQL Enterprise fields
- NATS fields
- NetFlow fields
- Nginx fields
- Office 365 fields
- Okta fields
- Oracle fields
- Osquery fields
- panw fields
- Pensando fields
- PostgreSQL fields
- Process fields
- RabbitMQ fields
- Redis fields
- s3 fields
- Salesforce fields
- Google Santa fields
- Snyk fields
- sophos fields
- Suricata fields
- System fields
- threatintel fields
- Traefik fields
- Windows ETW fields
- Zeek fields
- ZooKeeper fields
- Zoom fields
- Monitor
- Secure
- Troubleshoot
- Get help
- Debug
- Understand logged metrics
- Common problems
- Too many open file handlers
- Registry file is too large
- Error loading config file
- Contribute to Beats
editYou may have configured Logstash or Filebeat incorrectly. To resolve the issue:
Make sure that Logstash is running and you can connect to it. First, try to ping the Logstash host to verify that you can reach it from the host running Filebeat. Then use either
nc
ortelnet
- Verify that the config file for Filebeat specifies the correct port where Logstash is running.
Was this helpful?
Thank you for your feedback.
